whiteangel10 Posted May 22, 2012 Posted May 22, 2012 I have a problem with Autocad 2007. 1.When I try to edit something by double click it seems like I have unchecked the double click editing user preferences. I cannot edit unless I use the edit command from the command line not from the keyboard. 2. I also have problems with aother command(ex: copy/move).For example, after the copy command and the selection of the object for copying insted of performing the command, the pickbox apears and I cannot copy unless I select again the object with the pickbox.(I attach a photo...). Thank you in advance! Quote
whiteangel10 Posted May 22, 2012 Author Posted May 22, 2012 [ATTACH=CONFIG]34927[/ATTACH] The photo.. Quote
MSasu Posted May 22, 2012 Posted May 22, 2012 Please check that the PICKFIRST system variable is set to 1. Also, please check that your picture seems to don't be properly attached. Quote
whiteangel10 Posted May 23, 2012 Author Posted May 23, 2012 Thank you MSasu, that's was the problem! Quote
