JohnM Posted May 24, 2012 Posted May 24, 2012 anyone having issues with ssget "i" on autocad 2012 it will return the selection set but when i follow it with a command function the command function gives me an error like the command structure is wrong. it works in 2004 and 2006 example: (defun c:test () (setq ss (ssget "i")) (command "move" "previous" "") ) i get an error Command: TEST Point or option keyword required. ; error: Function cancelled when it should ask for a base point. if i delete the ssget it works fine. Quote
MSasu Posted May 24, 2012 Posted May 24, 2012 Maybe: (defun c:test1 () (if (ssget "_I") (command "_MOVE" pause pause) ) ) Quote
JohnM Posted May 24, 2012 Author Posted May 24, 2012 thanks for the responce it does not matter what i do, the "ssget "i causes a problem with any edit command. move-copy-change-rotate all these commands ask to select an object that is why i used the previous option in the command. this is where it errors. i use ssget i Implied selection (objects selected while PICKFIRST is in effect to verify that a user has selected something on the screen then it runs the command. draw a couple of lines on layer x and have the program change the layers to layer 0 you draw the lines then you select the lines then run the program this works. it finds the previous set [font=Arial][color=#000000][color=#000000][font=Arial](defun c:test ()[/font][/color][/color][/font] [font=Arial][color=#000000] [color=#000000][font=Arial](command "change" "previous" "" "properties" "layer" [/font][/color] [font=Arial][color=#000000]"0" "")[/color][/font] [color=#000000][font=Arial])[/font][/color] [/color] [/font] this will not work [font=Arial][color=#000000][color=#000000][font=Arial](defun c:test ()[/font][/color][/color][/font] [font=Arial][color=#000000] (if (ssget "i") [color=#000000][font=Arial](command "change" "previous" "" "properties" "layer" [/font][/color] [font=Arial][color=#000000]"0" "")[/color][/font] [color=#000000][font=Arial])[/font][/color] [color=#000000][font=Arial])[/font][/color] [/color] [/font] i get this error: Point or option keyword required. ; error: Function cancelled Quote
pBe Posted May 24, 2012 Posted May 24, 2012 (defun c:test () (if (ssget "i") (command "change" "_properties" "layer" "0" "") ) ) Quote
MSasu Posted May 24, 2012 Posted May 24, 2012 If there is an implied selection when you call the routine, then this will affect the behaviour of COMMAND call; seems that you didn't noticed that in my previous example. (defun c:test () (if (ssget "i") (command "_CHANGE" "_P" "_LAYER" "0" "") ) ) Quote
JohnM Posted May 24, 2012 Author Posted May 24, 2012 thanks for the responce. i just changed my program to use visual lisp functions and got rid of the command functions. now all is working correctly thanks JMH Quote
