Hello to all,
i need to draw many polyline and then once the offset of all.
Something like this draft:
(defun c:PolyOFF (var...)
(command "pline"); draw the polyline point by point, using the basic command of autocad.
(command "offset" "last"); offset polyline just drawn, using the basic command of autocad.
(command "erase" "previous"); erase the polyline drawn in the beginning.
Thanks for any help.
Regards.
For a single run
(defun c:test  nil
     (command "pline")
     (while (eq 1 (logand 1 (getvar 'cmdactive)))
           (command pause))
     (command "offset" "_erase" "Y" pause (entlast) pause)
It works fine!
Thanks a lot!
It works fine!
Thanks a lot!
Good for you marmo.
Glad I could help :)
Cheers
