leongtechno Posted May 28, 2012 Posted May 28, 2012 Dear sir, This problem for my 'Autocad lt2008'. Fatal error : unhandled e06d7363h Exception at 773f09eh. Quote
ReMark Posted May 28, 2012 Posted May 28, 2012 What were you doing, or attempting to do when the error occurred? Is this error repeatable? Does it happen in one particular drawing or any drawing that you are working on? Is your program current with all updates? Quote
leongtechno Posted May 29, 2012 Author Posted May 29, 2012 I just copy & paste pdf (Version:adobe reader x) into the drawing... I need update 'Autocad' in every month? If i want delete the pdf file, i need to use 'purge' to clear the file size? Quote
ReMark Posted May 29, 2012 Posted May 29, 2012 You did not answer all of my questions. No, you do not need to update AutoCAD every month. I was attempting to find out if you had ever installed any updates to AutoCAD 2008. If you want to delete the PDF you attached then do so. The PURGE command deletes unreferenced entities in a drawing file. It does not specifically, to my knowledge, delete attached PDFs. Quote
leongtechno Posted May 30, 2012 Author Posted May 30, 2012 My 'autocad lt 2008' is already update... After restart computer. The 'Autocad' is not problem to use. What mean of this 'unhandled e06d7363h Exception at 773f09eh' ? this is mean my 'computer / autocad / drawing(file)' error? You did not answer all of my questions. Quote
ReMark Posted May 30, 2012 Posted May 30, 2012 Are you saying this is NOT an AutoCAD related problem? Re: Unhandled exception error. "Unhandled Exception problems can include program lock-ups, slow PC performance, system freezes, blue screen, shutdown or startup problems, and installation errors." Quote
