Moving linkage causes lockup!!?
Hello Everyone! Perhaps one of you could help me with a problem that I am
having. The situation is this: In an assembly file I have two hinges one of
them is fastened to a framework on one side and a panel on the other, the
other is fastened to the other end of that panel and to another panel on the
other side. This forms a bi-fold door the last panel of which has a roller that
runs in a curved track in the framework. The Problem Is: when I try to move
the roller along the track(having placed a transitional constraint) the display
freezes and the program stops responding for about 3 minutes after which
everything seems normal.
Changing from hardware to OpenGL drivers had no effect, What is going
on? Does anyone have an idea?
I am stumped!
Geoff
the display
Never had that problem, what spec is the machine, do you have enough memory? can you post the model and I will check it this end.
Lazer, The machine in question is a dual core, about 2.5 ghz speed with
2 gigabyte of memory installed, that leaves me with about 600 megabytes
when the SQL server is running. Should be more than enough, the problem
might lie with the graphics card which is a fast and powerful ATI - but not
Autocad certified.
That being said I think the problem was a dumb mistake that I made in
applying two transitional constraints that were not co-planer at thier junction.
Drawing works as intended now, this is probably the trouble with self-education!
Geoffrey
