Hi
pls anyone can change this LISP for my convenient purpose.I have a LISP from cadtutor;this one good works.I need to change the color of destination object (color 240).
And I need another LISP number increment following below.
K3HB1-300X600
K3HB2-300X600
K3HB3-300X600
K3HB4-300X600
K3VB1-300X600
K3VB2-300X600
K3VB3-300X600
K3VB4-300X600
for preparing beam schedules
Advance Thanks
venki
COPYTEXT.lsp
To modify the color you may add this line into that code:
    ) ;_ if
  ) ;_ list
) ;_ vl-catch-all-apply
[color=magenta] (vlax-put-property x 'Color 240)
[/color])
;; unable to extract text, must not be able to edit it
(T
(and (vl-consp #TargetEnt)
     (alert "Cannot edit text within selected object!")
) ;_ and
Thank you very much of information and I need to help another LISP for doing beam schedule following below (increment number & change).
K3HB1-300X600
K3HB2-300X600
K3HB3-300X600
K3HB4-300X600
K3VB1-300X600
K3VB2-300X600
K3VB3-300X600
K3VB4-300X600
onceagain Thanks a lot!
venki
QUOTE=MSasu;478659]To modify the color you may add this line into that code:
    ) ;_ if
  ) ;_ list
[color=magenta](vlax-put-property x 'Color 240)[/color]
(T
) ;_ and
Thanks for information;then I will check Mr.lee program.
Venki
