Command keys in toolbars
Is it possible to put only specific command buttons from the toolbars on my interface while excluding others.
Thank you, this helped very much!
You can also create toolbars via Notepad with custom icons its pretty easy here is an example the bmp's are the images for the buttons stored in the location set by "config custom icon location" you can add any ACAD commands & icons also just found this a bit easier than finding a command amongst the hundreds and dragging to new cui, allows simple edits and just a new menuload.
***MENUGROUP=CONTOURS
***TOOLBARS
**ALANSCONTOURS
ID_ALAN    [_Toolbar("Contours", _LEFT, _Show, 0,0, 1)]
Alloff   [_Button("All Off","Alloff.BMP","alloff.BMP")]^c^c^c(setq surface "_ All Off")(load "vercheck")(load "listselect")(load "changecontours6")
50mm [_Button("50mm cont","50mm.BMP","50mm.BMP")]^c^c^c(setq surface "_ NS 0.05 Contours")(load "vercheck")(load "listselect")(load "changecontours6")
100mm [_Button("100mm cont","100mm.BMP","100mm.BMP")]^c^c^c(setq surface "_ NS 0.1 Contours")(load "vercheck")(load "listselect")(load "changecontours6")
200mm [_Button("200mm cont","200mm.BMP","200mm.BMP")]^c^c^c(setq surface "_ NS 0.2 Contours")(load "vercheck")(load "listselect")(load "changecontours6")
500mm [_Button("0.50m cont","500mm.BMP","500mm.BMP")]^c^c^c(setq surface "_ NS 0.5m Contours")(load "vercheck")(load "listselect")(load "changecontours6")
1m [_Button("1m cont","1m.BMP","1m.BMP")]^c^c^c(setq surface "_ NS 1m Contours" )(load "vercheck")(load "listselect")(load "changecontours6")
Triangles [_Button("Triangles","TRI.BMP","TRI.BMP")]^c^c^c(setq surface "_ NS Triangles" )(load "vercheck")(load "listselect")(load "changecontours6")
