Ravenstown Posted June 14, 2012 Share Posted June 14, 2012 With my viewport set at "2D wireframe", all object lines show regardless of elevation which can make it difficult to read and hard to really get the idea of what is going on in the drawing. Therefore I changed my viewport to "hidden" in an attempt to depict what is higher in elevation over lower objects by having the higher objects cancel out lower objects when running over them. For some reason it works with conduit running over conduit but when the conduit runs over other objects (that are lower in elevation) created with the box command the lines do not get broken.. the lower box object actual cancels out the higher conduit object?? How can I achieve the effect that I want? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted June 14, 2012 Share Posted June 14, 2012 Use draworder and see if that works. Quote Link to comment Share on other sites More sharing options...
Ravenstown Posted June 14, 2012 Author Share Posted June 14, 2012 I tried "bring to front", "send to back", "bring above object" & "send under object" but did not get any changes to the display results. Could it be a setting in the "Visual Styles Manager"? Quote Link to comment Share on other sites More sharing options...
