anilanand Posted June 22, 2012 Posted June 22, 2012 The MASSPROP command tells me this thing has an area of 0.785 square meter. I can run MASSPROP on it and get some information but how would one determine how much weight for aluminum would be involved with this and how could I calculate? I want to know the weight of extrusion in kg/m. and also show how?al ex.dwg Quote
MSasu Posted June 22, 2012 Posted June 22, 2012 You will need to multiply the said profile area with the length of the profile to get the volume - presuming that the profile is straight; next multiply again with the density of wanted material. Please pay attention to consistency of measuring units. For a curved profile, just model it in 3D and apply again MASSPROP command to get the volume. Quote
anilanand Posted June 22, 2012 Author Posted June 22, 2012 thanks for your reply... can u go through the attachment and tel the weight? plz? Quote
anilanand Posted June 22, 2012 Author Posted June 22, 2012 can u tel me wht is the density of aluminium ? Quote
SEANT Posted June 22, 2012 Posted June 22, 2012 Based on a density of 2.70 g·cm−3 : I’m getting about 2.12 kg per meter of extrusion. By the way, 785.3803 square mm should be 0.000785 square meters. Quote
MSasu Posted June 22, 2012 Posted June 22, 2012 You can find the density of Aluminium in imperial units (you stated inches in first post) here; but please pay attention that this is for pure material - for alloys may be different. Quote
anilanand Posted June 22, 2012 Author Posted June 22, 2012 thanks 2.70 g·cm−3=2700 kg/m-3 is this is ryt? Based on a density of 2.70 g·cm−3 : I’m getting about 2.12 kg per meter of extrusion. By the way, 785.3803 square mm should be 0.000785 square meters. Quote
SEANT Posted June 22, 2012 Posted June 22, 2012 Yes,though it would be written as either: 2700 kg·m−3 Or 2700 kg/m3 Quote
JD Mather Posted June 22, 2012 Posted June 22, 2012 ...how could I calculate Are you a student? Autodesk Inventor does this for you. Students can download Inventor for free from http://www.autodesk.com/edcommunity Quote
Manila Wolf Posted June 25, 2012 Posted June 25, 2012 If you are not using LT, I can point you to a very good lisp that I use. Can be found on this thread: - http://www.cadtutor.net/forum/showthread.php?50384-Calculating-weight-of-2d-shape-amp-3dsolid-object-by-asigned-material&highlight=calcwt I use a density of 2.71 g/cm^3 for aluminium extrusions. Densities of other materials can be added within the lisp. Quote
Dadgad Posted June 25, 2012 Posted June 25, 2012 (edited) Welcome to the forum. The MASSPROP command is used with 3D solids, and units reported are volumetric (cubic), not area. Should you want to PRESSPULL a profile defining group of lines to a length of 1000 (mms = 1 meter) you could then use the MASSPROP command on the resultant 3D solid object, and in that way you would get a reasonably accurate kg/m weight of a given profile. If I am not mistaken the MASSPROP command will provide you the volume in cubic mms, if working on a metric template. You can move the decimal point to the left by nine decimal places, effectively dividing it by 1,000,000,000 (1000 x 1000 x 1000) to convert the units of volume from cubic millimeters to cubic meters. Having done that you can multiply it by 2700 (the nominal weight of a cubic meter of aluminum). Of course you could alternately multiply the MASSPROP volume by .000002700 kgs, which would be a nominal cubic millimeter weight. Edited June 25, 2012 by Dadgad Quote
Manila Wolf Posted June 25, 2012 Posted June 25, 2012 If you are not using LT, I can point you to a very good lisp that I use.Can be found on this thread: - http://www.cadtutor.net/forum/showthread.php?50384-Calculating-weight-of-2d-shape-amp-3dsolid-object-by-asigned-material&highlight=calcwt I use a density of 2.71 g/cm^3 for aluminium extrusions. Densities of other materials can be added within the lisp. As a footnote.....The lisp(s) on this thread can also be adapted to calculate the actual weight of any single 3D solid. Quote
