gS7 Posted June 24, 2012 Posted June 24, 2012 (defun c:Test () (setq grt (getreal "\nEnter Greater Then Value:")); "101" (setq less (getreal "\nEnter Less Then Value:"));"102" (setq ss (ssget)) (setq cntr 0) (repeat (sslength ss) (setq ssnme (ssname ss cntr)) (setq ent (entget ssnme)) (setq value (atof (cdr (assoc 1 ent)))) (if (and (< value less) (> value grt)) (command "Chprop" ssnme "" "c" "2" "") (command "chprop" ssnme "" "c" "3" "") ) (setq cntr (1+ cntr)) ) ) i want to change color in between 101 and 102 value 101.233 101.455 101.786 101.322 sorry for my poor english tank u Quote
MSasu Posted June 24, 2012 Posted June 24, 2012 First, please pay attention that the color is stored under DXF code 62, not 1. Also, there is one exception - when the color is attached as ByLayer. Then the code 62 isn't available and you will need to check the color of container layer (DXF code . Quote
David Bethel Posted June 24, 2012 Posted June 24, 2012 You may want to try: [b][color=BLACK]([/color][/b]defun c:test [b][color=FUCHSIA]([/color][/b]/ grt less ss en ed cl[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]initget 1[b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]setq grt [b][color=NAVY]([/color][/b]getreal [color=#2f4f4f]"\nGreater Than Value: "[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]or [b][color=MAROON]([/color][/b]not less[b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]<= less grt[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]initget 1[b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]setq less [b][color=MAROON]([/color][/b]getreal [color=#2f4f4f]"\nLess Than Value: "[/color][b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]and [b][color=NAVY]([/color][/b]setq ss [b][color=MAROON]([/color][/b]ssget[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b] [b][color=NAVY]([/color][/b]while [b][color=MAROON]([/color][/b]setq en [b][color=GREEN]([/color][/b]ssname ss 0[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq ed [b][color=GREEN]([/color][/b]entget en[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]or [b][color=GREEN]([/color][/b]setq cl [b][color=BLUE]([/color][/b]cdr [b][color=RED]([/color][/b]assoc 62 ed[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b] [b][color=GREEN]([/color][/b]setq cl 256 ed [b][color=BLUE]([/color][/b]append '[b][color=RED]([/color][/b][b][color=PURPLE]([/color][/b]62 . 256[b][color=PURPLE])[/color][/b][b][color=RED])[/color][/b] ed[b][color=BLUE])[/color][/b][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]entmod [b][color=GREEN]([/color][/b]subst [b][color=BLUE]([/color][/b]cons 62 [b][color=RED]([/color][/b]if [b][color=PURPLE]([/color][/b]<= grt cl less[b][color=PURPLE])[/color][/b] 2 3[b][color=RED])[/color][/b][b][color=BLUE])[/color][/b] [b][color=BLUE]([/color][/b]assoc 62 ed[b][color=BLUE])[/color][/b] ed[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]ssdel en ss[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] It gives you: some basic input error checking testing for equal values (entmod) in lieu of (command) BYLAYER inclusion -David Quote
Lee Mac Posted June 24, 2012 Posted June 24, 2012 Are you looking to change the colour based on the content of selected Text? If so, consider: (defun c:test ( / cl dx en gt in lt ss vl ) (if (and (setq lt (getreal "\nSpecify Lower Bound: ")) (progn (while (and (setq gt (getreal "\nSpecify Upper Bound: ")) (< gt lt) ) (princ (strcat "\nUpper Bound must be greater than " (rtos lt))) ) gt ) (setq ss (ssget "_:L" '((0 . "TEXT") (1 . "*#*")))) ) (repeat (setq in (sslength ss)) (setq en (entget (ssname ss (setq in (1- in))))) (if (setq vl (distof (cdr (assoc 1 en)))) (progn (if (< lt vl gt) (setq cl '(62 . 2)) (setq cl '(62 . 3)) ) (if (setq dx (assoc 62 en)) (entmod (subst cl dx en)) (entmod (append en (list cl))) ) ) ) ) ) (princ) ) Quote
pBe Posted June 24, 2012 Posted June 24, 2012 i want to change color in between 101 and 102 value 101.233 101.455 101.786 101.322 I guess those values are just an example FWIW: Quick mod for the code you posted, (defun c:Test ( / grt less ss cntr str) (setq grt (getreal "\nEnter Greater Then Value:")) (setq less (getreal "\nEnter Less Then Value:")) (setq ss (ssget [color=blue]"_:L" '((0 . "*TEXT"))))[/color] (setq cntr 0) (repeat (sslength ss) (setq ssnme (ssname ss cntr)) (setq ent (entget ssnme)) [color=blue](setq str (cdr (assoc 1 ent)))[/color] [color=blue](if (numberp (setq value (read str)))[/color] [color=blue] (entmod (append ent (list (cons 62 (if (< grt value less)[/color] [color=blue] 2 3)))))[/color] [color=blue] )[/color] (setq cntr (1+ cntr)) )(princ) ) Quote
pBe Posted June 24, 2012 Posted June 24, 2012 Are you looking to change the colour based on the content of selected Text? Thats is what i had in mind too Lee (setq ss (ssget "_:L" '((0 . "TEXT") (1 . [color=blue]"*#*"[/color])))).... I keep forgetting about that filter ... Quote
gS7 Posted June 25, 2012 Author Posted June 25, 2012 Tank u Guys .......... Thanx for Your Support Quote
