Hi all,
As i am new to the programming my skill is too less to sort out my problem and after a lot of try (with no success) i came to you all. Just give me a hint.
I have a polyline (Route) drawn with the circles (location) besides it.
Just want to know how can i sort those circles as if it is a right hand side of polyline (positive) and if it is a left hand side of polyline (negative).
Attach drawing is a reference to understand.
Sample.dwg
Please give me a solution.
Thanks in advance.
This could be a start for you
(defun C:TEST ( / cross_prod ss1 ss2 e1 e2 p1 p2 i v tg)
 (defun cross_prod (a b)
 (list (- (* (cadr a) (caddr b)) (* (caddr a) (cadr b)))
   (- (* (caddr a) (car b)) (* (car a) (caddr b)))
   (- (* (car a) (cadr b)) (* (cadr a) (car b)))
 (if
   (and
     (setq ss1 (ssget ":E:S" '((0 . "LWPOLYLINE,SPLINE"))))
     (setq ss2 (ssget '((0 . "CIRCLE"))))
     (setq e1 (ssname ss1 0))
     (repeat (setq i (sslength ss2))
       (setq e2 (ssname ss2 (setq i (1- i)))
             p2 (cdr (assoc 10 (entget e2)))
             p1 (vlax-curve-GetClosestPointTo e1 p2)
             v (mapcar '- p1 p2)
             tg (vlax-curve-GetFirstDeriv e1 (vlax-curve-GetParamAtPoint e1 p1))
         (vla-put-Color (vlax-ename->vla-object e2) (if (minusp (caddr (cross_prod v tg))) acRed acYellow))
Thank You So Much Stefan BMR.
You're welcome.
FWIW, also works on line, circle, arc and ellipse
