Bª™ªN1534592500 Posted July 3, 2012 Posted July 3, 2012 Hi Is is possible to extract the properties of the blocks in a particular drawing (i.e. block name, x coordinates, y coordinates and rotation) and prints a comma delimited text file output? Sample text file output will be like the following: TypeK,30.415,15.601,90 TypeI,111.015,15.601,90 TypeA,111.015,28.201,90 TypeG,126.615,28.201,0 TypeK,126.615,48.941,90 TypeK,142.215,48.941,90 TypeK,142.215,99.601,0 TypeK,30.415,99.601,0 TypeK,38.215,99.601,0 TypeI,46.015,99.601,90 Thanks. Quote
BlackBox Posted July 3, 2012 Posted July 3, 2012 DATAEXTRACTION is more complete, I just happened to code something similar recently, and thought I'd post. Take from this what you will. (defun c:BlockProp (/ *error* ss path acApp acDoc oShell file coord) ;; RenderMan, 2012 (princ "\rBLOCKPROP ") (vl-load-com) (defun *error* (msg) (if oShell (vlax-release-object oShell)) (if file (close file)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** ")))) ; Fatal error, display it (princ)) (if (and (setq ss (ssget "_x" '((0 . "INSERT")))) (setq path (strcat (vl-filename-directory (vl-filename-mktemp)) "\\Block Properties.csv")) (setq acApp (vlax-get-acad-object)) (setq acDoc (vla-get-activedocument acApp)) (setq oShell (vla-getinterfaceobject acApp "Shell.Application"))) (progn (setq file (open path "w")) (write-line "BLOCK PROPERTIES" file) (write-line "" file) (write-line (strcat "Drawing:, , " (getvar 'dwgprefix) (getvar 'dwgname)) file) (write-line (strcat "Date:, , " (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD)")) file) (write-line "" file) (write-line "NAME, X, Y, Z, ROTATION" file) (vlax-for oBlock (setq ss (vla-get-activeselectionset acDoc)) (write-line (strcat (vla-get-effectivename oBlock) "," (rtos (car (setq coord (vlax-get oBlock 'insertionpoint)))) "," (rtos (cadr coord)) "," (rtos (caddr coord)) "," (rtos (vla-get-rotation oBlock))) file)) (setq file (close file)) (vlax-invoke oShell 'open path) (*error* nil)) (*error* "No blocks found"))) Quote
Bª™ªN1534592500 Posted July 3, 2012 Author Posted July 3, 2012 Thanks guys. DATAEXTRACTION command gives very detailed output and very powerful. RenderMan, that's cool, I never expect that lisp can be able to do that. Quote
BlackBox Posted July 3, 2012 Posted July 3, 2012 Thanks guys. DATAEXTRACTION command gives very detailed output and very powerful. As I do not have the need for this command, I often forget about it (hence the code). RenderMan, that's cool, I never expect that lisp can be able to do that. That is kind of you to say; Lee and many others helped me come to learn much of what I now know. Quote
Bª™ªN1534592500 Posted July 3, 2012 Author Posted July 3, 2012 RenderMan, I encountered an error and not opening the csv file under the temporary file. I just modified the path name and it works perfectly. Here's the code that works for me: (defun c:BlockProp (/ *error* ss path acApp acDoc oShell file coord) ;; RenderMan, 2012 (princ "\rBLOCKPROP ") (vl-load-com) (defun *error* (msg) (if oShell (vlax-release-object oShell)) (if file (close file)) (cond ((not msg)) ; Normal exit ((member msg '("Function cancelled" "quit / exit abort"))) ; <esc> or (quit) ((princ (strcat "\n** Error: " msg " ** ")))) ; Fatal error, display it (princ)) (if (and (setq ss (ssget "_x" '((0 . "INSERT")))) (setq path C:\\Users\\ZAGM01373\\Documents\\Batman.csv") ;Please change this to your preferred file path and name (setq acApp (vlax-get-acad-object)) (setq acDoc (vla-get-activedocument acApp)) (setq oShell (vla-getinterfaceobject acApp "Shell.Application"))) (progn (setq file (open path "w")) (write-line "BLOCK PROPERTIES" file) (write-line "" file) (write-line (strcat "Drawing:, , " (getvar 'dwgprefix) (getvar 'dwgname)) file) (write-line (strcat "Date:, , " (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD)")) file) (write-line "" file) (write-line "NAME, X, Y, Z, ROTATION" file) (vlax-for oBlock (setq ss (vla-get-activeselectionset acDoc)) (write-line (strcat (vla-get-effectivename oBlock) "," (rtos (car (setq coord (vlax-get oBlock 'insertionpoint)))) "," (rtos (cadr coord)) "," (rtos (caddr coord)) "," (rtos (vla-get-rotation oBlock))) file)) (setq file (close file)) (vlax-invoke oShell 'open path) (*error* nil)) (*error* "No blocks found"))) Quote
BlackBox Posted July 3, 2012 Posted July 3, 2012 That's very strange, as it (the code I posted) not only works well on my end, but according to the developer documentation uses your environment's temporary settings. More on vl-Filename-Mktemp function. Rather then hard-coding the location for each user, perhaps identify a common directory that will work for your setup, and use (getvar 'loginname) to remove the need for each user to modify. Just a thought. Quote
Bª™ªN1534592500 Posted July 4, 2012 Author Posted July 4, 2012 I tried it again and it's working now. I don't know why yesterday the csv file is not opening after the command. Probably the problem is just I didn't wait long enough for the lisp to open it, because I tried it several times and I was forced to locate the file manually. Thanks a lot, I will use your original code. Quote
asos2000 Posted July 4, 2012 Posted July 4, 2012 RenderMan, I encountered an error and not opening the csv file under the temporary file. I just modified the path name and it works perfectly. Here's the code that works for me: (defun c:BlockProp ... The wrong in your code is (defun c:BlockProp ... (setq path [color="red"]C[/color]:\\Users\\ZAGM01373\\Documents\\Batman.csv") Should be (defun c:BlockProp ... (setq path[color="red"] "C[/color]:\\Users\\ZAGM01373\\Documents\\Batman.csv") Quote
goØn Posted July 4, 2012 Posted July 4, 2012 Good topic Bª™ªN That's also very generous for you to share that bit of code RenderMan, so thank you, Quote
BlackBox Posted July 4, 2012 Posted July 4, 2012 Batman - I'm glad you got everything working. Go0n - Always happy to help. Quote
