npgtech Posted November 1, 2008 Posted November 1, 2008 I have the following problem with AutoCad MEP 2009. I use a Property Set to define a custom Label Style for Devices. When I'm trying to select the Device Object that I want the label to be assigned to, I get the message “0 found”. For the same reason, I cannot assign labels to schematic symbols as well, but there seems to be no problem with other kind of objects, such as ducts and pipes. Notice that things work perfect with AutoCad MEP 2008. Any suggestions? Thanks in advance. Quote
kwortman Posted March 6, 2009 Posted March 6, 2009 I am having a similar issue. I can label my devices in drawing that the devices were placed, but i cannot label the same devices if i try to label them through an xref. I know this does not help you npgtech, but i did not want to start a new thread with a similar problem. Thanks in advance Quote
