AstroNout Posted July 6, 2012 Posted July 6, 2012 Hi guys I've been busy again. I've tried to come up with a (dated) VBA-Code do disbow my drawings. But I can't seem to cycle through the polylines in the drawing. Shouldn't it be: If TypeOf aEnt Is AcadPolyline Then It doesn't work at all... Thanks y'all! Quote
AstroNout Posted July 9, 2012 Author Posted July 9, 2012 how are LW's stuctured? Without z-coordinates? So X1,Y1,X2,Y2 etc. in the array? Quote
SEANT Posted July 9, 2012 Posted July 9, 2012 That's correct. With a Elevation property as the overriding Z value for all vertices, and a per vertex Bulge factor to indicate arcs. The "LightWeight Polyline" situation can get a little complex depending on 3d alignment of the Normal property. The TranslateCoordinate Method must be used when comparing to World coordinates. Quote
