ziauddinm Posted July 10, 2012 Posted July 10, 2012 Hi, Im electrical Engr. i use poly lines for wiring, after compleating all the routing, i need to calculate the total length of poly line, tlen wont calculate if line is broken at a point. Help ? Quote
rkmcswain Posted July 10, 2012 Posted July 10, 2012 Hi, Im electrical Engr. i use poly lines for wiring, after compleating all the routing, i need to calculate the total length of poly line, tlen wont calculate if line is broken at a point. Help ? Hello. I moved your post to its own thread. So TLEN will not work? I don't understand why. I can break a polyline into 2 parts and still use TLEN to give me the total length of both segments. Quote
MSasu Posted July 10, 2012 Posted July 10, 2012 Ziauddinm,, you may also check the solutions suggested in this previous discussion. Quote
