AstroNout Posted July 10, 2012 Share Posted July 10, 2012 Hi all! The weather isn't too good over here, so it's programmingtime again. Could you get me out of this one? It should mark the height of a block, but I get stuck when I try to put the text on the insertionpoint of the block. Not too complicated I guessed. I guessed wrong... The error states: "Method 'Add3DMesh' of object 'IAcadModelSpace' failed." Sub BlockHeight() Dim aEnt As AcadEntity Dim aBlock As AcadBlockReference Dim aText As AcadText Dim sText As String Dim NewLayer As AcadLayer Dim retValue As Variant Dim retCoord(0 To 2) As Double Dim attrib As Variant Dim sset As AcadSelectionSet Dim FilterType(0) As Integer Dim FilterData(0) As Variant Dim InsertionPoint As Variant FilterType(0) = 8 FilterData(0) = "OCT_KDT" On error GoTo Delete Set sset = ThisDrawing.SelectionSets.Add("sset") sset.Select acSelectionSetAll, , , FilterType, FilterData On error goto Errorhandling For Each aEnt In sset If TypeOf aEnt Is AcadBlockReference Then Set aBlock = aEnt retValue = aBlock.GetAttributes For Each attrib In retValue If attrib.TagString = "LAYER" Then sText = attrib.TextString End If Next attrib If sText Like "N_WRI*" Then Set NewLayer = ThisDrawing.Layers.Add("N_LOW") sText = aBlock.InsertionPoint(2) InsertionPoint = aBlock.InsertionPoint Set aText = ThisDrawing.ModelSpace.AddText(sText, InsertionPoint, 0) aText.Layer = "N_LOW" aText.StyleName = "OCTOPUS" aText.Height = 0.5 aText.Rotation = 0 NewLayer.Color = acYellow End If End If Next aEnt sset.Delete Exit Sub Delete: ThisDrawing.SelectionSets.Item("sset").Delete Resume Errorhandling: ThisDrawing.SelectionSets.Item("sset").Delete End Sub Quote Link to comment Share on other sites More sharing options...
