TroutKing Posted July 10, 2012 Posted July 10, 2012 Hi Everyone, Is someone out there able to help me with this? I am trying to create some code that allows the user to click on one attribute at a time – and each time an attribute is selected its text style resets back to its default. Example – on the attached drawing: AttributeTest.dwg Block “CONTACT-8” on the very left side of the drawing has three attributes. The first attribute has had “75” entered. When this attribute is double clicked you can see that under the “Text Options” tab the Text Style has been adjusted. I want to click that particular attribute and have only that attribute go back to its default Text Style (STANDARD in this case.) I do NOT want any of the other attributes to be adjusted. I want only that one to be adjusted and then the user can move on to the next block containing the next attribute they choose to return to its default. I want to continue through the drawing until the user clicks enter twice to end the macro. I’m not really sure how approach this. I began with the code below (which does not work), but I don’t think this is the correct approach after all because it would change all the attributes for the selected block as opposed to just the selected attribute. Option Explicit Public Sub SelectBlockAndUpdateTextStyle() Dim MyBlock As AcadBlockReference Dim SelectedBlock As Variant Dim i As Variant ThisDrawing.Utility.GetEntity MyBlock, SelectedBlock, "Select object:" If MyBlock.ObjectName = "AcDbBlockReference" Then If MyBlock.HasAttributes Then Dim MyBlockAttribute As Variant MyBlockAttribute = MyBlock.GetAttributes For i = LBound(MyBlockAttribute) To UBound(MyBlockAttribute) If Not MyBlockAttribute(i).TextStyle = "STANDARD" Then MyBlockAttribute(i).TextStyle = "STANDARD" End If ThisDrawing.Application.Update Next End If Else MsgBox "You didn't select an AutoCAD block. Better luck next time." End If End Sub Is there anyone who can help me and point me in the right direction? I definitely appreciate your help Thank you, Mike Quote
TroutKing Posted July 11, 2012 Author Posted July 11, 2012 Hmmm crickets again. Well either I'm not good at explaining my dilemma(s) or perhaps my questions are uninteresting or/and unsolvable. With a few adjustments I made the code work for an entire block (see below). It will adjust the attributes within the chosen block and set them to their original standard values. However, it adjusts ALL the attributes in the chosen block. I only want to change the attribute that was selected with the cursor. Any ideas out there? Option Explicit Public Sub SelectBlockAndUpdateTextStyle() Dim MyBlock As AcadBlockReference Dim SelectedBlock As Variant Dim i As Variant Dim MyWidth As Integer MyWidth = 1# ThisDrawing.Utility.GetEntity MyBlock, SelectedBlock, "Select object:" If MyBlock.ObjectName = "AcDbBlockReference" Then If MyBlock.HasAttributes Then Dim MyBlockAttribute As Variant MyBlockAttribute = MyBlock.GetAttributes For i = LBound(MyBlockAttribute) To UBound(MyBlockAttribute) If Not MyBlockAttribute(i).StyleName = "STANDARD" Then MyBlockAttribute(i).StyleName = "STANDARD" MyBlockAttribute(i).ScaleFactor = MyWidth End If MyBlockAttribute(i).Update Next End If Else MsgBox "You didn't select an AutoCAD block. Better luck next time." End If End Sub Quote
BlackBox Posted July 11, 2012 Posted July 11, 2012 Hmmm crickets again. Well either I'm not good at explaining my dilemma(s) or perhaps my questions are uninteresting or/and unsolvable. Don't take it personal... It is more likely that you're not getting (much?) support, as you're coding in VBA, rather than in Visual LISP, or .NET, methinks. I could be mistaken, as I am not adept at coding VBA, but perhaps using GetSubEntity Method in lieu of GetEntity Method would be advantageous, no? Quote
TroutKing Posted July 11, 2012 Author Posted July 11, 2012 Thanks Oleg I replied to your email Thank you RenderMan. I like that possible solution. I looked into it and will need to work with it, but it may just work for my needs. Thanks! I realize that I'm going to have to move on to one of the other programming languages. I've been holding out. I'm disappointed in AutoCAD for moving away from a language that has been used for many years and can be used in other applications (i.e. Excel). I know nothing of Visual LISP or .NET. Perhaps they work in other applications as well? Quote
BlackBox Posted July 11, 2012 Posted July 11, 2012 Thank you RenderMan. I like that possible solution. I looked into it and will need to work with it, but it may just work for my needs. Thanks! You're welcome; hope it helps. I realize that I'm going to have to move on to one of the other programming languages. I've been holding out. I'm disappointed in AutoCAD for moving away from a language that has been used for many years and can be used in other applications (i.e. Excel). I know nothing of Visual LISP or .NET. Perhaps they work in other applications as well? Well, VBA has been 'dead or dying' through attrition for years, and is no longer supported by MS. Interestingly, however, is that in a recent developer survey the option of VBA7 was listed, though it did not have many votes. So you never know. Visual LISP, while syntactically different than that of VBA, allows one access to both the LISP API, and the ActiveX API (i.e., VBA). I still have access to Document and Application level Objects, and can even interface with external Objects. Too many examples to post them all, but as a small sample set, these include Scripting.FileSystemObject, Shell.Application, WScript.Shell, and even Sapi.SpVoice Objects. More on getting started with .NET development for AutoCAD. HTH Quote
TroutKing Posted July 11, 2012 Author Posted July 11, 2012 Actually that helped a lot. I have some code now that works for what I need. I need to somehow add a "Do Until" user clicks "ENTER" twice or something to that effect so that the macro will continue running until the user is done, but your help definitely pointed me in the right direction. I appreciate it. I didn't realize that MS no longer supports VBA either. Thats good to know. I appreciate the link. I guess I'm going to have to bite the bullet and begin Visual LISP or .NET as a newbie . If you (or anyone willing to help) has some input as to how to make the routine below continue as long as the user wishes - please feel free to point me along the right path Thank you again! Option Explicit Sub Example_GetSubEntity() Dim Object As Object Dim PickedPoint As Variant, TransMatrix As Variant, ContextData As Variant Dim MyStyle As String Dim MyWidth As Integer Dim i As Variant MyStyle = "STANDARD" MyWidth = 1# On Error GoTo NOT_ENTITY TRYAGAIN: ThisDrawing.Utility.GetSubEntity Object, PickedPoint, TransMatrix, ContextData If Not Object.StyleName = MyStyle Then Object.StyleName = MyStyle Object.ScaleFactor = MyWidth End If Object.Update Exit Sub NOT_ENTITY: If MsgBox("You have not selected an object. Click OK to try again.", _ vbOKCancel & vbInformation) = vbOK Then Resume TRYAGAIN End If End Sub Quote
BlackBox Posted July 11, 2012 Posted July 11, 2012 You're welcome; happy to help. Just a guess, but consider the 'Do...Loop', using the While keyword? ... Oleg knows _far_ more than I about this. Quote
TroutKing Posted July 11, 2012 Author Posted July 11, 2012 I think I can make a Do loop work with one or the other - either the "Until" or the "While" keyword. However, I do not know the proper syntax to say "until the user hits ENTER" twice or something similar. I'm not very familiar with your work here but I agree with your insight on Oleg. He has helped me more that I could ever repay (if I wasn't a poor broke drafter) over the years. He is an awesome source of help as well as a friend Thank you again Quote
fixo Posted July 11, 2012 Posted July 11, 2012 what the biggest trout you caught for these years? e-mail me, I've forgot about Quote
TroutKing Posted July 11, 2012 Author Posted July 11, 2012 Ha! Fishing has not been very productive this year. Way too busy with my fourth child only 8 months old. OK, with the help I received here and my other research and the beginning of a bald spot on the side of my head from scratching while thinking, I was able to get this to work. I'm not sure how stable it is but it works. If anyone want's to adjust it to make it better - please feel free! I don't get my feelings easily hurt from constructive critism! Just ask Oleg. I can't tell you how many times he has reached over the internet and thumped me in the head! Option Explicit Sub Example_GetSubEntity() Dim Object As Object Dim PickedPoint As Variant, TransMatrix As Variant, ContextData As Variant Dim MyStyle As String Dim MyWidth As Integer Dim i As Integer Dim REPLY As String MyStyle = "STANDARD" MyWidth = 1# On Error GoTo NOT_ENTITY TRYAGAIN: Do ThisDrawing.Utility.GetSubEntity Object, PickedPoint, TransMatrix, ContextData If Not Object.StyleName = MyStyle Then Object.StyleName = MyStyle Object.ScaleFactor = MyWidth End If Object.Update Loop Exit Sub NOT_ENTITY: REPLY = MsgBox(" You have not selected an attribute" & vbCr & vbCr & "Press RETRY to continue or CANCEL to end the macro", vbRetryCancel, " A SPECIAL MESSAGE JUST FOR YOU") If REPLY = 4 Then Resume TRYAGAIN End If End Sub Quote
fixo Posted July 11, 2012 Posted July 11, 2012 If you used 'Option Explicit' better yet to cast all object explicitly, so you have to cast an object as AttributeReference Set attRef = Object then change its properties, you will be avoid many mistakes in your code I posted you another loop example, sorry, not tested See you, Quote
