line command at a 22.5 degrees and a certain length, or any degree with length.
Welcome to the forum bigtimmy, and may I be the first to commend the clarity of your first question. :)
The answer provided by nestly is referred to as direct distance entry. This is how is works...http://www.cadtutor.net/tutorials/autocad/direct-distance-entry.php
Yes, indeed it would be. Thank you for the correction.
