When I use my autoCAD at the office to create a Sheet set file I allways get the
message "Unable to Create a sheet Set file". Is there a way correct this problem.
I am using AutoCAD 2012 on a network. I have tryed to create sheet set files on my
local C: drive and other drives without any luck.
Thank you,
Do other people in the office have the ability? Could you try a repair install?
