ahguter Posted July 18, 2012 Posted July 18, 2012 I am attempting to keep the cable line of the crane always tangent to the circle at the top of the crane. The length of the crane (including the circle at the top) is being polar stretched but i am unable to keep the cable tangent to the top circle as i stretch and rotate the crane. Help would be appreciated. Quote
dbroada Posted July 18, 2012 Posted July 18, 2012 I think you will need to add geometric constraints to the block. That is the simple answer. Unfortunately I am not in a position give a fuller one as I have only worked my way through the AutoDesk guide once and have forgotten all that I learned. Quote
ahguter Posted July 18, 2012 Author Posted July 18, 2012 ive got that but it just wont length as the crane does Quote
dbroada Posted July 18, 2012 Posted July 18, 2012 can you post your block. At the moment I can't visualise what you are talking about. Quote
ahguter Posted July 18, 2012 Author Posted July 18, 2012 here it is that line at the top is what im trying to maintain Manitowoc 2250.dwg Quote
ahguter Posted July 18, 2012 Author Posted July 18, 2012 Thanks for the help... i got it though. a few lock constraints and an additional stretch did the trick. Quote
dbroada Posted July 19, 2012 Posted July 19, 2012 good. I still haven't looked at your block but I thought a tangent restraint would fit what I thought you were describing. With my brief look at geometric constraints I can see they will be useful, I just need time to look. Quote
