vertical horizons Posted July 18, 2012 Posted July 18, 2012 (edited) We just upgraded to 2013, and we now have "Tube & Pipe". I ran "Pipe Run" a few times to familiarize myself with it. But it would sure help if I could go through a tutorial. Does anyone know whether anyone has posted a tutorial for "Pipe Run"? ********Disregard******** Thanks to JD Mather, I was able to locate a tutorial. If anyone is interested in the tutorial, it can be found here ... http://wikihelp.autodesk.com/Inventor/enu/2013/Help/0126-Tutorial126/1042-Tube_and1042/1043-Get_Star1043/1046-Create_a1046 Edited July 18, 2012 by vertical horizons update Quote
vertical horizons Posted July 18, 2012 Author Posted July 18, 2012 I am reading the "Pipe Run"tutorial, and now have a question ... I am at the section that says - Create segments using precise dimension values. The next part says- "... Right-click in the graphics window and verify that Auto-Dimension is enabled ..." but when I right-click in the graphics window, I don't see where I would verify that the Auto-Dimension is enabled. BTW, the tutorial appears to be from Inventor 2009 or before. We are using Inventor 2013. Quote
vertical horizons Posted July 18, 2012 Author Posted July 18, 2012 ... The next part says-"... Right-click in the graphics window and verify that Auto-Dimension is enabled ..." but when I right-click in the graphics window, I don't see where I would verify that the Auto-Dimension is enabled ... ********Disregard******** I figured it out. You DO right-click in the graphics window, BUT your mouse has to be ON ONE OF THE PROJECTED LINES. Quote
