ThisDrawing Property with AutoCAD 2013
I am currently recompiling code to be compatible with AutoCAD 2013.
The original code was created using the "Magic Macro" to convert VBA code over to VB.NET code using COM Interface.
I have ran into an issue when trying to create a ThisDrawing property for the rest of the code to use.
In AutoCAD 2012 this way worked just fine:
Public ReadOnly Property ThisDrawing() As AcadDocument
Get
Return Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
End Get
End Property
But in AutoCAD 2013 that way no longer works.
I get an 'Unable to cast COM object of type 'System.__ComObject' to interface type 'Autodesk.AutoCAD.Interop.AcadDocument' exception.
I have tried several different ways to accomplish this. Many with examples from the internet, but to no avail.
Some failed attempts:
       Get
           Return DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument)
       End Get
End Property
       Get
           Return CType(DocumentExtension.GetAcadDocument(Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument), AcadDocument)
       End Get
End Property
Public ReadOnly Property ThisDrawing() As Object
       Get
           Dim DotNetDoc As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
           Dim oDoc As Object = DocumentExtension.GetAcadDocument(DotNetDoc)
           Return oDoc
       End Get
End Property
       Get
           Dim tAcadDoc As Autodesk.AutoCAD.ApplicationServices.Document
           Dim tAcadDocCOM As Autodesk.AutoCAD.Interop.AcadDocument
           tAcadDoc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
           tAcadDocCOM = CType(Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(tAcadDoc), Autodesk.AutoCAD.Interop.AcadDocument)
           Return tAcadDocCOM
       End Get
End Property
Has anyone else encountered this problem or already figured out how to accomplish this with AutoCAD 2013?
Thank you,
Kraut1976
I know VBA used AcadDocument
But why do you have to use Acaddocument in dot net. Why not just use Document?
Private ThisDrawing As Document = Application.DocumentManager.MdiActiveDocument
or
Public ReadOnly Property ThisDrawing() As Document
Get
End Get
End Property
I have to use AcadDocument because the code was converted from VBA to VB.NET using Autodesk's "magic macro". The converter uses COM interface to facilitate the conversion.
I found what the problem was. It was a rookie mistake. LOL
I failed to change my references to use the new AutoCAD 2013 type libraries.
Once I referenced the correct libraries, and changed all references to AutoCAD.Interop and AutoCAD.Interop.Common over to the new AxDBLib assembly then everything fell into place and now the following code works correctly.
       Get
       End Get
End Property
  • 7 months later...
Hi Kraut1976,
I have read your post and wonder if you could provide more information on changing the references to AxDBLib. I have not been able to find any documentation on that library
Thanks
Colin
  • 11 months later...
I was struggling wit this too. You have to add references from your autocad program folder (X:\Program files\Autodesk\Autocad 2014\). Find Autodesk.AutoCAD.Interop.dll and Autodesk.AutoCAD.Interop.Common.dll . After that, magically appeared for me, but see if you are missing from ObjectARX2014 or 2013 folder and if so then add the following: AcCoreMgd.dll ; AcDx.dll. Then you can use the following:
Public ReadOnly Property ThisDrawing As AcadDocument
       Get
           Return Application.DocumentManager.MdiActiveDocument.GetAcadDocument()
       End Get
   End Property
  • 1 month later...
Thanks Codeplayer. All I had to do was swap the references of Autodesk.AutoCAD.Interop.dll and Autodesk.AutoCAD.Interop.Common.dll from the ones in ObjectARX2014 to "X:\Program files\Autodesk\Autocad 2014\".
