aloy
Limiting the input value of a variable
aloy
How can I limit the input value for a variable?.
I tried the following lisp unsuccessfully:
(defun c:limit()
 (setq s
(while (and (< s 2.5) (> s 7)) (setq s(getreal "\nGive value between 2.5 and 7:")))
Thanking in advance.
Aloy
Share this post
Link to post
MSasu
Those conditions cannot be met simultaneously:
(defun c:limit()
(setq s
(while ([color=red]or[/color] (< s 2.5)
           (> s 7.0))
 (setq s (getreal "\nGive value between 2.5 and 7.0: "))
Share this post
Link to post
Tharwat
(defun c:limit (/ in)
 (while
   (not
     (or (< (setq in (getreal "\n Give value between 2.5 and 7:"))
        2.5
     (> in 7)
    (princ "\n ** Must be Less than 2.5 or Biggar than 7.0 **")
Share this post
Link to post
MSasu
Tharwat, I'm afraid that your code is in fact rejecting the values it should accept and vice versa; there is also a conflict among prompter, respectively error message:
 (while
   (not
     ([color=red]and[/color] ([color=red]>=[/color] (setq in (getreal "\n Give value between 2.5 and 7:"))
        2.5
     ([color=red]<=[/color] in 7)
    (princ "\n ** Must be Less than 2.5 or Bigg[color=red]e[/color]r than 7.0 **")[color=red]   ;?!?[/color]
Edited by MSasu
Fixed code to accept limits of interval too
Share this post
Link to post
BlackBox
Also consider the INITGET function.
Share this post
Link to post
Tharwat
My understanding of the Op goal is to accept the values between 2.5 to 7.0 and that's what my code does .
I don't get what conflict you are talking about !
I got not error message with Cad 2013
Share this post
Link to post
MSasu
That's true, "between"! Your routine accept only values outside this interval...
Sorry, but mathematical logic isn't influenced by AutoCAD's version.
Share this post
Link to post
aloy
Hi Msasu,
Thanks very much. It works fine.
Aloy
Share this post
Link to post
aloy
Hi Tharwat,
Thanks for the code. It works; needs a correction to the string to give the intended meaning.
Regards,
Aloy
Share this post
Link to post
aloy
RenderMan,
I thought 'INITGET' functions accept certain values, but not values within a defined range.
Regards,
Aloy
Share this post
Link to post
BlackBox
Sorry for any confusion; perhaps I can clarify:
Technically, you're only presenting the user an illusion of limiting the value at the time of input, when in fact any real number input is accepted, and then checked to ensure the entered value falls within the desired range prior to continuing with your function.
INITGET is useful at 'Limiting the input value of a variable' (this thread's title), and not at ensuring that the user's real number input falls within a certain range after being entered, which is what is being done in the specific case you're after here.
It's use (INITGET) here would only be useful if you were attempting to prevent non-Nil, or even negative values being entered. Given the completeness of verifying that the user's input falls within the specified range, this is not necessary.
In any event, HTH
Share this post
Link to post
aloy
RenderMan,
You are correct. Thanks,
Aloy
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
