addesigns Posted July 24, 2012 Posted July 24, 2012 I am running Revit Architecture 2011. When I print to PDF using CutePDF and I have elements hidden they sdo not show as hidden when the PDF is complete and I am looking at it. How can I fix this? Quote
SLW210 Posted July 24, 2012 Posted July 24, 2012 Doesn't Revit Architecture 2011 have the ability to print or export directly to PDF? Why are you using CutePDF? Quote
SLW210 Posted July 24, 2012 Posted July 24, 2012 Try another PDF program. I use PrimoPDF at home. Haven't used CutePDF in a while. Quote
addesigns Posted July 24, 2012 Author Posted July 24, 2012 Have you ever ran into the poblem that I stated above. I figure if it is hidden then it would not show up in the PDF. I will have to check out PrimoPDF. Quote
RobDraw Posted July 24, 2012 Posted July 24, 2012 If it is hidden with the V/G settings then it shouldn't print. If it is hidden using the temporary overrides then Revit will ask you if you want to print with the temporary overrides. Quote
addesigns Posted July 24, 2012 Author Posted July 24, 2012 Much appreciated, I will try that this evening. Quote
Lee Roy Posted July 30, 2012 Posted July 30, 2012 Doesn't Adobe have a free pdf printer driver? Quote
SLW210 Posted July 31, 2012 Posted July 31, 2012 Doesn't Adobe have a free pdf printer driver? Not that I know about. Quote
