Dswanson Posted August 14, 2012 Share Posted August 14, 2012 Hello I'm having a problem with a drawing I've been working on. When viewed with x-ray visual style on autocad 2012 the view used to smooth as if I were looking through glass. When I view the drawing with autocad 2008 I get small dots or "x" all over my solids. Now Ive worked on the drawing on 2008 saved it and opened it in 2012 and now the dots or "x"s are happening in both versions. I used to think it was a video card issue but now that it's happening both places it can't be. I'm mainly wondering how I get back the smooth glass look I had on 2012 version. When I get home later I can attach some pictures to help with what I'm describing. Any help would be greatly appreciated. Thank you Quote Link to comment Share on other sites More sharing options...
Dswanson Posted August 18, 2012 Author Share Posted August 18, 2012 If anyone else is havig this problem I've found the solution. The issued turned out to be in "options" > "system" > "performance" settings I changed the degradation order and put the transparency options to be last changed when memory is low. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 18, 2012 Share Posted August 18, 2012 If anyone else is havig this problem I've found the solution. The issued turned out to be in "options" > "system" > "performance" settings I changed the degradation order and put the transparency options to be last changed when memory is low. Thanks for the help. Welcome to the forum. Thanks for sharing your solution, adaptive degradation is a useful tool. Quote Link to comment Share on other sites More sharing options...
Mayehem Posted October 3, 2012 Share Posted October 3, 2012 The same thing just started happening to me in 2013. It was fine yesterday. All my video settings are on high performance and I moved transparency and transparency quality to the bottom of my degradation order. Closed and reopened AutoCAD and still not working. The worst part is the solids are printing to PDF like this! - Opacity of 99 or lower - Nvidia Feforce GTX 670M Please help! Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 3, 2012 Share Posted October 3, 2012 Do you have HARDWARE ACCELERATION enabled? If you do, then try turning it off, and see if that helps. If you don't, then try turning it on, and yes I know that sounds crazy, it is. Quote Link to comment Share on other sites More sharing options...
Mayehem Posted October 4, 2012 Share Posted October 4, 2012 Crazy it was. Hardware exceleration was turned off, even though I have never turned it off in my life! AutoCAD testing my sanity once again no dout. THANK YOU! Quote Link to comment Share on other sites More sharing options...
