Faouweb Posted August 17, 2012 Posted August 17, 2012 Hi As you can see in this picture, I have made an iso arrow and then block it, but when I want to use it in the Dimension arrow (user arrow)the block is rotated can you tell me where is the problem Thank you. Quote
MSasu Posted August 17, 2012 Posted August 17, 2012 From your picture seems that your custom arrow isn't aligned to horizontal when created the block. The angle between arrow and dimension line from left side of the picture seems to be equal with the rotation of arror in the right side (~30 degrees). Try to re-create it with the "axis" of that shape parallel with X axis. Quote
