Can't edit text.
TEXTEDIT is all that is needed, in 2013 at least.
  • Replies 23
  • neophoible
    10
  • BradDeVries
    8
  • SLW210
    4
  • rkent
    2
Yes, works in 2012 also, and in 2010. DDEDIT worked in 2008. This may be the best solution so far. Don’t pre-select. Start with TEXTEDIT (shortcut TEDIT?), then select the Attribute. No need to mess with the Group status at all.:thumbsup:
Nice. Thanks guys. Appreciate it a lot.
I found this interesting to look into. :geek: Note that Shift+Ctrl+A changes the PICKSTYLE setting, though it is not necessarily straightforward, since there are more than two options, at least in 2012 and up.
