Finding all dimensions with text overrides
Is there a quick way of finding all dimensions with a text override.
I am dimensioning screwed pipe, and want the cut length on the drawing, e.g. a pipe that is 3000mm between center of fitting should show a dimension of 2970. After doing this on a few hundred dimensions I want to check that I have not left any out. i therefore want to check if there is any way to check that they are all overridden.
thanks
Bryan
Not in LT. If you were using full AutoCAD I believe there is a custom lisp routine that will do what you want.
You have Quick Select in LT, right? You can select for Object Type = dimensions and for Text Override = blank.
