tangent to 2 different circles
Can anyone advise me how to get a line to form a tangent on 2 different circles, different sizes, different cntr lines. Got snap on, but still not right.
:oops:
When asked for first point by LINE command, just hold and right click; this will give you access to a Osnap modes menu that overrides current setting - select Tangent and pick the first circle (on circumference, in the part were you want the tangent). Repeat for second circle.
This forms a tangent on the second circle, but not on the first, or am I missing something?
It would works for first one too - did you tried above instructions? Will notify that after apply on first circle, the tangency point is somehow dynamical; it will get the final location only after set the second one.
Mircea is, as usual, correct. :beer:
There will be no line created until after you have selected the second circle.
There could be a problem if you have other conflicting OSNAPS turned on,
like PERPENDICULAR, QUADRANT, NEAREST ........ If you try with just the TANGENT OSNAP activated you shouldn't have any trouble. :)
