Block attribute text to annotative
Changing the properties of text within attributed blocks through lisp, namely;
  • Text to annotative (in this case, I require 1:1)
  • Text Position Locked
Can this be done?
The only other alternative is to redefine each block?
Cheers,
H
Uhm ... yes ... even in lisp you'd be redefining blocks. BTW, are you sure you want the text inside the block to become annotative? I'd usually leave the attribute/text to be non-anno and set the entire block to be anno as a whole, else you get strange results.
  • 2 weeks later...
It is for the title block, which, in paper space would not (normally) be annotative. However, I am running a VB Macro to update attributes, and to overcome using the attsync command, making the text annotative seems to work. I have just redefined all of the blocks with a script. Weird, but it works. All good. Thanks for your reply. H.
