rotate in a sketch, with copy, doesn't work
I use the rotate command with the copy option, i see the result, but when i press Done-it returns to the beginning, nothing happens.
I attach the file, i am trying to make a circular array of the 2 lines and arc, but first i want to copy and rotate them only 20 degrees.
Leroy Somer 56M.ipt
Works here for me, but - you should
Circular Pattern of Features, not sketches.
This has been covered here before.
Do this experment-
while in edit sketch right click and select Show All Constraints.
Now do you see why you should create a simple sketch with a simple feature and pattern that rather than the sketch?
