rock1 Posted September 10, 2012 Posted September 10, 2012 software like indesign and coreldraw allow you to align centres of texts and objects. for example if i have written the word bedroom and a rectangle of 3000 by 4500 is therem, i can select the text and the rectangle. press the aign to centre button and these two things will align their centres. how can i do that in autocad? Quote
Manila Wolf Posted September 10, 2012 Posted September 10, 2012 I think not so simple in AutoCAD. One way is to make the text justification middle centre. Then use the "move" command, use the insert osnap to snap to the base point of the text, then type M2P, then click on the top left hand corner of the rectangle then click on the bottom right hand corner of the rectangle. Quote
ReMark Posted September 10, 2012 Posted September 10, 2012 Another option. Insert your text then use the Express Tools command TCIRCLE to enclose the text with a Circle, a Slot or a Rectangle centered on the text. TCIRCLE can be found in the TEXT option of Express Tools. Quote
