samartk Posted September 12, 2012 Posted September 12, 2012 Hi all, I have a hundreds drawing need to change tag number inside drawing for example: Does anyone have some application to auto change it. Thank You in advance. Samart K Quote
Dadgad Posted September 12, 2012 Posted September 12, 2012 Welcome to the forum. I believe that Lee Mac may have just what the doctor ordered, great programming! http://www.lee-mac.com/programs.html#general Probably worth taking a look, he just might have what you need. Thanks Lee! Quote
SLW210 Posted September 12, 2012 Posted September 12, 2012 Are the Tag numbers text, mtext, attributes or other? Quote
Lee Mac Posted September 12, 2012 Posted September 12, 2012 This may help you: http://lee-mac.com/bfind.html @Dadgad, thanks for the recommendation as always Quote
samartk Posted September 13, 2012 Author Posted September 13, 2012 Lee, We can't import data from exel file right? Quote
Lee Mac Posted September 13, 2012 Posted September 13, 2012 Lee, We can't import data from exel file right? Start the BFind program and enter a few random items, then click 'Save' to save the search items and create the save file. Close the BFind program and type at the command-line: (findfile "LMAC_BFind_SavedSearches_V2-0.txt") Navigate to this file and open it. Copy your find / replace items from Excel to this file, and ensure that you match the existing formatting of the file. Start the BFind program and click 'Load' to load the items copied to file. Quote
samartk Posted September 15, 2012 Author Posted September 15, 2012 Thank you for wonderful solution Lee:notworthy::notworthy: Quote
samartk Posted September 15, 2012 Author Posted September 15, 2012 Lee I already try Bfind program but the the result is search and generate report only (not replace)how to set it to search and replace:cry: Quote
samartk Posted September 15, 2012 Author Posted September 15, 2012 OK lee pls. ignore previous one I can do it already. Quote
