jcoots17 Posted September 12, 2012 Posted September 12, 2012 Can someone please help. Having trouble with the benchmark for plate 1 in civil project. When i go to put in coordinates it puts a mark way off screen not even close to where the benchmark is suppose to be at. Thanks!! Quote
ReMark Posted September 12, 2012 Posted September 12, 2012 Well you are at least in the right forum. This specific question has been asked and answered a handful of times and it usually comes down to the user inputting the wrong coordinates. What coordinates are you working with? Have you set the LIMITS as per the instructions? Did you happen to look at any of the threads regarding Penn-Foster Civil project? Quote
jcoots17 Posted September 13, 2012 Author Posted September 13, 2012 yeah i looked at the instructions again. For some reason i logged out and then started over with a new page and reset the limits and units and it worked the first time. Sometimes it works right the first time other times it doesnt. Anyways it worked almost done with plate 1. Thanks for the quick reply. Greatly appreciated!! Quote
ReMark Posted September 13, 2012 Posted September 13, 2012 Let's hope that you do not have to start from scratch every time something does not work right otherwise it will take you much longer to do the project than it should. Maybe things will go smoother for you from here on out. Good luck. You're entirely welcomed. Quote
