checkovich Posted September 13, 2012 Share Posted September 13, 2012 Hello, I need some adivice on making 2d drawings of Pump stations, septic tanks, wells - here are some examples : http://eccua.ee/wp-content/uploads/KP2500_est.pdf http://eccua.ee/wp-content/uploads/KP2500_est.pdf What program should i use ? If i add block to drawing can i get the specifications of the object automatically into a table, just like in example drawings. Thank you Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 13, 2012 Share Posted September 13, 2012 Plain AutoCAD can be used but if you do a lot of piping layout you might want to look at AutoCAD MEP. As long as the block has attributes then "yes" the attached information can be extracted to a table. Quote Link to comment Share on other sites More sharing options...
