Arty Posted September 17, 2012 Share Posted September 17, 2012 Is it possible to copy a line in Plot Style Table, in my case red nr 1, and have two with different linetype? I have a drawing where this specific line and the text belonging to it should be in red, (line 1) and the lines dashed. If I in my Plot Style Table make line 1 dashed, the text get dashed too... At the moment I have put another color to the dashed lines, but if there is a way to have two red nr1 lines with different linetype, it would be great! Quote Link to comment Share on other sites More sharing options...
Tiger Posted September 17, 2012 Share Posted September 17, 2012 I had to look up my Plot Style Table to see if it was indeed so that you can assign a line type there - I never noticed that before. So thanks for teaching me something new! I always have linetype set on the individual layers and the Line Type in the Plot Style Table set as Use Object Style. So sorry, can't help you. But if it turns out you can indeed make a copy of the Red-color, and set that to dashed - wouldn't that mean you have what you have now? Two colors, one set on the lines and one set on the text? Just that they are both red? You can take whatever color you like (12 for instance) and match the properties from Red to that color so that they are virtually identical. I guess I just don't see why you need to copy Red... Quote Link to comment Share on other sites More sharing options...
Arty Posted September 17, 2012 Author Share Posted September 17, 2012 You're welcome I did as you suggested. Line nr 12 is quite similar in color so that'll work! Tack for hjalpen Quote Link to comment Share on other sites More sharing options...
