Need some help with CTB and STB files.
Hi people,
since this is my first post on this website, I would like to introduce myself. My name is Manny and Im currently a Architecture major in my first semester in San Diego, CA...
Im currently trying to receive extra credit in my AutoCad class to bump up my grade to an "A".... My teacher is allowing me to choose a topic in AutoCAD that we havent covered and teach the class that topic for extra credit. Well, I chose creating CTB and STB files.
In order for me to recieve credit I need to:
  • state the difference between an STB and a CTB file
  • create a CTB file and draw a simple drawing using it (like 4 walls and some doors)
  • show the class how to create a CTB file using the wizard.
This is probably some pretty straight forward stuff to many of you, but, I really would like some advice from some professionals like yourselves. Any advice would help.... Im looking for ideas on how to go about this assignment, and how to teach a class on creating CTB files.
Thanks for the help in advance. you rock!
this topic was recenly debated and people brought up good points about each
check here
as for the others, you can search posts on this site or just google it and find some good tutorials...
if you finish it and are willing to share...there is a forum on this site for tutorials and im sure many people would benifit from you sharing your completed tutorial with us.
Have you checked Help in AutoCAD yet??
Thats were i would start. Than maybe ask questions about what you dont understand
After your research and you put together your notes for teaching the subject, can we get a copy?
In fact, you can practise the class on us. I'll volunteer to be the troublesome student that doesn't understand no mater how clear you explain it.
It won't be a tough act for me
There is a lot of misinformation concerning CTB and STB and so I am offering this as my input to the issue. I like STB’s over CTB’s for my situation,
You will have to explore the alternatives and make an informed choice for your office.
Advantages \ Disadvantages
CTB =
Plot style name (IE:Color_43) is not intuitive to plot color or LW or gray scale
26 linewieghts, same as in STB
Lots of legacy drawings that need to be brought forward and used again, easier to keep
CTB Plot style name cannot be changed
Limited to plot colors of 1-255, other colors show on screen but are plotted out to 1-255
Familiar system still used by majority of users
Plotting b/w there are fewer reasons to switch as STB was meant more for electronic color plotting (according to Autodesk)
If I want 15 colors to plot screened and medium
thickness I must edit 15 plot style names, then 15 more for other LW, etc
Sharing files between offices means that the plot style names will always be there, just defined differently for each color, still have to go through and
check plot name style to plotted color, width, etc.
XREFs, the xref file can be set to plot to a thinner line weight but the color will be one color displayed
on screen, or you will have to pick each color and assign a plot style name
STB =
Plot style names are intuitive (IE: BW 0.40, Thin Color, Medium, GRAY
0.25) for knowing color and LW plotted using Bylayer allows familiar colors known to plot thin, thick etc, to still be obvious on screen
Plotting black and white and color on the same sheet is easier due to intuitive plot style names
26 lineweights, same as in CTB
Probably can get by with 15 or 20 plot style names, CTB you always have 255 all named with a color
If 15 colors need to plot screened and medium thickness only 1 plot style name is edited and assigned to multiple colors, results in much fewer plot style names needed
If other offices use their own style names, using their files will result in assigning the plot style name to ones you use, unless everyone agrees to use
the same plot styles
XREF's, the xref file can be set to plot to a thinner line weight with one plot style name and the colors on screen will still display the same color, and they
can be set to display one color if need be
Editing the plot styles can be done
through the layer manager or properties palette
STB's work just fine, and just like CTB's you must have standards in place
You can still set colors to indicate lineweights just like CTB's
You can set a layer to a color and have it plot to any lineweight with a plotstyle
You can set each object to a plot style or mix and match, but this is not a strategy for working drawings, more for one off presentation drawings, etc.
More flexibility in setting up and this equals more ways for users to screw it up
LINKs:
A good article discussing the differences between STB and CTB.
Cadalyst.com
http://management.cadalyst.com/cadma....jsp?id=102922>
A good article on one firm's adoption of STB's. This is just one way of
many ways to set up STB standards so don't read this as the only way to use
STB's.
AUGI.com
May/June 2005 issue, page 24
