rodrigo_sjc_sp Posted October 9, 2012 Posted October 9, 2012 Is there any way to SET a polyline with 3 alternate colors? Ex: colors (yellow, red, green) The polyline turns yellow after 1 second turns red after 1 second turns green, and the end of her green back to yellow in an infinite loop? What I need is to draw attention to the Polyline defective in design, and thought to set one or more colors and let them alternating between polyline. Quote
rodrigo_sjc_sp Posted October 9, 2012 Author Posted October 9, 2012 Is there any way to create a timer in LISP, 1 in 1 second it executes the command to change the color? Need more control timer because once you see the problem, I need to stop it, and set a neutral color. Quote
Lee Mac Posted October 10, 2012 Posted October 10, 2012 (defun c:flash ( / *error* cmd col ent enx old ) (defun *error* ( m ) (if old (entmod (append ent old))) (if cmd (setvar 'cmdecho cmd)) (princ) ) (if (setq ent (car (entsel))) (progn (setq enx (entget ent) old (list (cond ((assoc 62 enx)) ('(62 . 256)))) cmd (getvar 'cmdecho) col 2 ) (setvar 'cmdecho 0) (while (= 5 (car (grread t 13 1))) (entmod (append enx (list (cons 62 (setq col (1+ (- 2 col))))))) (command "_.delay" 150) ) (entmod (append enx old)) (setvar 'cmdecho cmd) ) ) (princ) ) Quote
rodrigo_sjc_sp Posted October 10, 2012 Author Posted October 10, 2012 Thank You Lee , The code was exactly what I needed. Quote
Tharwat Posted October 10, 2012 Posted October 10, 2012 The code was exactly what I needed. What about these people whom spend their time just to help you and you didn't even blink on them with any . http://www.cadtutor.net/forum/showthread.php?73287-find-unclosed-polylines Quote
Lee Mac Posted October 10, 2012 Posted October 10, 2012 Thank You Lee , The code was exactly what I needed. You're welcome. Quote
