Hi,
How do I unlock a locked xref for editing??
I have a title block i want to edit the text in, but it's locked! Don't know how this happened, nor how to unlock it...
What do you mean by locked? Is it read only or opened by somebody else? Are you trying to edit it from the drawing that it is inserted into or are you in the actual file being XREFd?
I loaded it into my drawing. Then tried to edit some text in the xref while it was loaded in the drawing, but it woulden't let me. It said that it had a file lock...? Today, I tried it all again and now there's no problem! No idea what happened, but it all works fine now !?! :)
Would like to know how to unlock an xref in case it happen again though!
The only thing that "locks" in AutoCAD are layers and viewports, off the top of my head. Sounds like it was on a layer that was locked - that's it. ;)
XREFs can be "locked" from being editted from the referenceing file. I believe it is in the demand load settings but not sure...
Maybe Dadgad will come by and give a screen shot of the variable for this.
Here you go Rob, ask and you shall receive. :beer:
Ah, I see now. I thought that was for performance only. Makes sense... but only if someone else was referencing the XREF with a XLOADCTL = 1, I assume?
With it set to 2 you are no longer referencing the XREF file but a temporary copy of that file in a different location. Reference manager is disabled for XREFs when it is set to 2. If it wasn't disabled, you would editting a copy of the XREF and the changes would not be seen in other files referencing it. Editting the XREF file is allowed even if files that reference it are open.
