Simple153
Trimming Polyline 2013
Simple153
We have a number of Spline Blocks that we use to elevate houses to mimick a random stone pattern.
We have never had a problem trimming these blocks until 2013.
Now when we insert the premade block of stone spline and try to trim out where a window or door are the whole block dissappears which is rather frustrating!!!
If you select a edge to trim to the spline object cannot be selectred to trim.
When you drop a boc around the spline to select it the whole spline is deleted.
Any ideas would be welcome
Simon
Share this post
Link to post
SLW210
Are you using AutoCAD or Architecture?
What command(s) are you using?
Share this post
Link to post
Simple153
Autocad and trim.
Share this post
Link to post
ReMark
Could you post a copy of a sample block?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
