Simple153 Posted October 23, 2012 Share Posted October 23, 2012 We have a number of Spline Blocks that we use to elevate houses to mimick a random stone pattern. We have never had a problem trimming these blocks until 2013. Now when we insert the premade block of stone spline and try to trim out where a window or door are the whole block dissappears which is rather frustrating!!! If you select a edge to trim to the spline object cannot be selectred to trim. When you drop a boc around the spline to select it the whole spline is deleted. Any ideas would be welcome Simon Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 23, 2012 Share Posted October 23, 2012 Are you using AutoCAD or Architecture? What command(s) are you using? Quote Link to comment Share on other sites More sharing options...
Simple153 Posted October 23, 2012 Author Share Posted October 23, 2012 Autocad and trim. Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 23, 2012 Share Posted October 23, 2012 Could you post a copy of a sample block? Quote Link to comment Share on other sites More sharing options...
