I have a BOM from EXCEL that I have pasted into ACADe as AutoCAD Entities.
These BOMs have different formatting (font, color, alignment).
I want a LISP routine that will clean up the table (remove colors, all same text size, correct alignment). I don't want to use OLE because there is additional info in the spreadsheet that we do not need in the drawing.
Here is some code I have that make the columns the correct size and alignment.
I still need:
- Make background fill NONE
- Set text height to same
- Change first two columns to WHOLE NUMBER
I have attached a sample of what I am talking about.
Thank You In Advance!
(defun c:ResizeTable()
(vl-load-com)
(setq tbl (vlax-ename->vla-object(car(entsel))))
(vla-setcolumnwidth tbl 0 0.525)
(vla-setcolumnwidth tbl 1 0.525)
(vla-setcolumnwidth tbl 2 1.5)
(vla-setcolumnwidth tbl 3 3.075)
(vla-setcolumnwidth tbl 4 1.5)
(vla-setcolumnwidth tbl 5 1.0)
(setq rows (vla-get-rows tbl)) ;;get number of rows
(setq currentRow 0)
(repeat rows - 2 ;;repeat for all the rows in the table
(vla-SetCellAlignment tbl currentRow 0 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 1 acMiddleCenter)
(vla-SetCellAlignment tbl currentRow 2 acMiddleLeft)
(vla-SetCellAlignment tbl currentRow 3 acMiddleLeft)
(vla-SetCellAlignment tbl currentRow 4 acMiddleLeft)
(vla-SetCellAlignment tbl currentRow 5 acMiddleCenter)
;;(vla-setrowheight tbl currentRow 1) ;Change row height (TEST)
(setq currentRow (+ 1 currentRow))
TEST.dwg
