Philllip Posted October 31, 2012 Posted October 31, 2012 Is there possible to use dimbreak on symbols (welding, surface texture etc.)? Maybe this can be solved in some other way? // Philip Quote
SLW210 Posted October 31, 2012 Posted October 31, 2012 How are your symbols created? DIMBREAK works on Multileaders and Dimensions. Quote
Philllip Posted October 31, 2012 Author Posted October 31, 2012 Annotate > Symbols >... If dimbreak not work, is there any other way? I dont want to explode the symbols. Quote
SLW210 Posted October 31, 2012 Posted October 31, 2012 Annotate > Symbols >...If dimbreak not work, is there any other way? I dont want to explode the symbols. Never heard of Annotate>Symbols>... in AutoCAD. What program are you using? Quote
Philllip Posted October 31, 2012 Author Posted October 31, 2012 I'm using AutoCad Mechenical 2009. Quote
SLW210 Posted October 31, 2012 Posted October 31, 2012 You need to ask those familiar with Mechanical, those symbols have nothing to do with Vanilla AutoCAD. I'll move your thread. Quote
Marvin7 Posted April 29, 2013 Posted April 29, 2013 In the help file, DIMBREAK and AMDIMBREAK both say they are to create "breaks in dimensions" as specific points. Doing either command lists "Select dimension or extension line to break", so fairly obviously, that's all you can break, with those commands at least. I'm not aware of another command that will hide a portion of a linear object without the need to split the object into multiple subobjects. Quote
