ckaramfilov
Autocad 2013 presspull freeze
ReMark
Here is just one example where the underlying geometry is faulty. See the two areas I circled in red? Lines overlap other lines instead of ending cleanly. When AutoCAD encounters something like this it gets confused. It will try to make sense of it but if it can't then it will lock up. Understand?
The other problem for you is that you are probably attempting to use the command on a much larger area of the drawing which means AutoCAD is most likely encountering many more of these anomalies.
Share this post
Link to post
ckaramfilov
Damn so i need to redraw everything?
Share this post
Link to post
ckaramfilov
No cant select an object to use it. When i click on the icon next to the extrude box it freezes. I am not trying to do anything on the model. Thats why i think that it can be a sofware problem
Share this post
Link to post
ReMark
I would try not to redraw everything if I could possibly avoid it. You might however try finding and correcting the problems and working on smaller areas. Since much of your drawing consists of similar objects maybe do one section then copy it how many ever times you need. Follow me?
Share this post
Link to post
ReMark
If the PressPull command works in another drawing but not this one then it is the drawing that is flawed and not a problem with AutoCAD.
Share this post
Link to post
ckaramfilov
Yes i follow you. I can make the model without the command using the extrude command but i wanted to use the new one
Share this post
Link to post
ReMark
In my opinion you could use the PressPull command but you'll have to clean up the geometry first. Then you'll have to work with a smaller subsection of the drawing.
Unfortunately I am in the middle of helping someone about 3000 miles away with a rather more vexing problem (via Skype) so I will have to leave this conversation within the next couple of minutes. However, since this site is open and visited 24 hours a day you might soon be assisted by another forum member so hang in there.
When is this due?
Share this post
Link to post
ckaramfilov
I have to make the model till monday
Share this post
Link to post
ReMark
When then you still have plenty of time. I think you can do it but it will take some work.
Sorry, but I have to beg off now. I will check back in the morning (Saturday). Leave a message about what progress you have made before signing off yourself. Good luck.
Share this post
Link to post
ckaramfilov
Thank you have i nice eavening :)
Share this post
Link to post
Alzer
Could i make a suggestion..
open autocad and create a new drawing. Determine if the presspull works..
Also from a quick glance at the drawing. As mark suggests. Do some cleaning up on it. If your handy with the trim command. If the lines intersect you can trim them. Esentially creating closed loops.
I would advise not using the 'select all' option due to the fact its freezing up.
Another idea would be to check your graphics tuning. I found from experience with using '3DCONFIG' and changing the settings it can cause the application to lock up
Share this post
Link to post
ckaramfilov
I am trying to trim atm but the problem is that autocad doesnt want to trim or extend the items
Share this post
Link to post
Alzer
I would take a quess and say the lines dont actually intersect, were the lines drawn on the same XY plane ??
Share this post
Link to post
ckaramfilov
i dont know i wasnt me who drew that
Share this post
Link to post
Alzer
Ah right. Presspull works for me on most of it. Works fine on the geometry in PLAN . On the elevations however i did manage to lock the app up a bit
There is a lot of unneeded geometry in it.
Maybe copy a section of it into a new drawing. Work on one section cleaning it up. You could copy or mirror your work then as a lot of it is the same
By copying a section of it to a new drawing your cutting down on the calculations required for the geometry
Share this post
Link to post
ReMark
ckara: You've now basically gotten the same advice from two different people. I suggest you start following it. The problem is not with AutoCAD itself but with your geometry.
Looking at the front of the building you have one section that is repeated one additional time (right end of building) and another section that is repeated three additional times. That means you really only have two sections that have to be extruded. You've already reduced your workload by two thirds.
Share this post
Link to post
