problem with drawing a solid model with autocad 2013
Here is my try:
[ATTACH]38619[/ATTACH]
RoseMari, I see you have a lot of help from others, I just played a litle bit with your drawing. The text is cut from the solid. And I used Solid Works.
For sure that isn't the way your instructor expects from you, so wait the advices from people using the software you use. As I mentioned before: I just played some.
thanks alot for your interest, it's really good way,
hope my instructor allow it because it's much easier than what he asked
  • Replies 27
  • RoseMari
    11
  • ReMark
    10
  • MSasu
    4
  • tomhamlet
    1
Posted Images
Add your name on the object itself? I suppose you could use the IMPRINT command although there is another possibility that comes to mind using text that has been exploded. I'll await you response first.
no I should add my name near to it (like a label for example), he want it like the following picture
he wants it simple, but in straight line, in autocad 2009 we use new ucs>face and it's worked, but I couldn't do it in autocad 2013
[ATTACH=CONFIG]38621[/ATTACH]
My feeble attempt yielded this using AutoCAD. It wasn't quite as easy as I may have lead you to believe.
I had to use the Express Tools command called TextExplode to first explode the text. Then I created regions of each letter. Note that in the instance of the 'R' and the 'O' I had to use the Subtract command on the inner parts of the letter. Next I extruded the letters into the block and then I subtracted them thus "cutting" them into my solid. The red that you see was done using the Color Faces command.
I can't see how your teacher would expect the students to know this technique. It is probably much, much easier to do something like this in Inventor or Solidworks.
wow :roll: you are perfect in autocad, and it's really hard for a beginner like me to do it every time :oops:
but thanks god he just want it simple , just like in the picture, but I really don't know how to make it straight like he did in autocad 2009, so I will be grateful if you can help me o:)
I think you may have gotten it RoseMarie. Nice job. Fun wasn't it?
I'm really grateful to you o:) and to everyone who tries to help me with it
yaa it's fun -->> especially when I finished it :P
I am far from perfect. There are forum members who make me look like a novice! But thanks just the same for the compliment.
I don't normally put text in a 3D model so you'll have to give me a moment. Off the top of my head I think it would just be a matter of reorienting your UCS.
Something like this?
I did this by rotating my UCS. To make sure the bottom of my text was at the same elevation as the bottom of my rectangular solid I also relocated my origin. I had to move the text to get it into the right position. I guess I could have drawn a reference line too but I forgot about that until I started typing this. I'm sure there is a better way to accomplish the same task. One of the smarter forum members will come along and give us both a lesson. You can count on that!:lol:
Simply type
UCS hit Enter
Type Face (or F) and hit Enter
Select the face where you want your text.
now do the text.
perfect comparing to me :P
rotating the UCS o:) yaa it's an idea ;) thanks for your hard work
I thought it will be like 2009 just click on face then type :P
and ya this is one of the smarter members you just mention :D
V
V
V
V
Simply type
UCS hit Enter
now do the text.
thanks alot , my problem was this one, I thought it is like 2009 :unsure:
but now everything is perfect thanks to you and to ReMark for the help :oops:
appreciate it
