Ahmeds
Select one object/entity, gripped all same entity within the layer
Ahmeds
What function should i use to do that? I'm planning to change all entities in one layer but its is hard to select by windowing/crossing method because i have many entities in my drawing, so, i want to just click one but gripped all objects in the same layer to change simultaneously in just one command.
Thanks in advance..
Share this post
Link to post
Lee Mac
QSelect / GetSel
Share this post
Link to post
Ahmeds
QSelect / GetSel
Thanks Lee, but as I go to Autodesk Help (AutoLisp Functions) to see an example as my reference I've notice that there is no functions such as Getsel.
can u please give me an example of that?
Share this post
Link to post
Tharwat
........... I've notice that there is no functions such as Getsel.
GetSel is a command , and Lee gave you two options so you can use either of them ;)
Share this post
Link to post
MSasu
A third built-in alternative is the FILTER command.
The GETSEL command is part of Express pack; for this reason it isn’t listed in AutoCAD’s help. If you cannot call it at command prompt, too, this may be from either the fact that you don’t have that extension installed, or that you are using the LT type of AutoCAD.
Share this post
Link to post
Ahmeds
Ok, I got you guys.. Thanks!
I tried this routine to make a selection and change all text heights in just one command but all I've got is error: bad argument type: lselsetp
Would you please help me to do this right..
(defun c:CTH ()
   (graphscr)
   ;(prompt "text height to change")(terpri)
   (setq a (car (entsel)))(terpri)
   (if a (setq a (cdr(assoc 8 (entget a)))
  	sslst(list (cons 0 "text")(cons 8 a))
   );end if
          (setq nh(getreal "New Text Height: "))
          ;(princ "\nWORKING\n")
       (setq N (sslength sslst))
         (setq n1 N)
         (repeat N
           (setq n1 (- n1 1))
           (setq b (ssname sslst n1))
           (setq c (cdr(assoc 0(entget b))))
           (if (= c "TEXT") (progn
               (setq e (entget b))
               (setq f (assoc 40 e))
               (setq g (atof(rtos(cdr f)2 6)))
               (entmod (subst(cons(car f) nh) f e))
Edited by Ahmeds
Share this post
Link to post
MSasu
That code attempts to treat a list as a selection set; I believe that this line:
sslst (list (cons 0 "text") (cons 8 a))
should be instead:
sslst [color=red](ssget "_X" [/color](list (cons 0 "text") (cons 8 a)[color=red])[/color])
Share this post
Link to post
Ahmeds
well, i got it now.. here it is..
(defun c:CTH ()
   (graphscr)
   (setq x (car (entsel)))(terpri)
   (if x (setq x (cdr(assoc 8 (entget x)))
  	sslst(list (cons 0 "text")(cons 8 x))
   );end if
   (setq a (ssget "x" sslst))
        (setq N (sslength a))
         (setq n1 N)
         (repeat N
           (setq n1 (- n1 1))
           (setq b (ssname a n1))
               (setq e (entget b))
Thank you Guys...
Edited by Ahmeds
Share this post
Link to post
MSasu
You should localize your variables and include the entire processing in the IF, or at least ensure that exit if user didn't select first text item. Just run your routine twice in a row, and second time do not select a text label, input a text height different than at first run and see what is happening.
Also, please edit the above port and add the required code tags. Thank you.
Share this post
Link to post
Tharwat
Pay attention to locked layers with the selection method "_x" ;)
Share this post
Link to post
Ahmeds
Thank you..
Share this post
Link to post
Tharwat
Thank you..
You're welcome
Don't forget to modify your post number 8# with Code Posting tags .
Share this post
Link to post
Ahmeds
You're welcome
Oppss, Sorry, Just a newbie.. I don't know how was it..
Share this post
Link to post
SLW210
Welcome to CADTutor Ahmeds!
You need to read the CODE POSTING GUIDELINES and add CODE tags to the code in post #8 and change the CODE in post #6 from QUOTE tags to CODE tags. Select "Go Advanced" at lower right of the edit box.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
