Epicurwin Posted November 27, 2012 Posted November 27, 2012 I had the UK version added to my MEP 2013 so that I could use hangers, thank you autodesk . Now I'm missing the tool pallets that have pipe, fittings, valves, ect. When I click on the tool palette it now shows two palettes that say, "New Palette" How do I get the standard pipe palettes back? Update: I couldn't get the palettes in the UK setup so I changed back to imperial us and still didn't have palettes. I then restarted MEP and the palettes are now showing up. Just changed the version to UK again and the tool Palettes disappeared and changed it back to Us and they returned so apparently only the UK version is missing them now. Quote
tzframpton Posted November 27, 2012 Posted November 27, 2012 Are you starting AutoCAD directly from the Icon that's related to the Profile? Or are you opening AutoCAD, then switching Profiles while the AutoCAD session is open? Quote
Epicurwin Posted November 27, 2012 Author Posted November 27, 2012 I've been switching profiles while CAD is open. Quote
tzframpton Posted November 27, 2012 Posted November 27, 2012 That's what I figured. I have had problems with losing Tools in the past by using this method as well. Starting fresh from the Icon seems to always work best. And good luck with the UK hangers rod and supports... I gave that crap up LONG ago. One of my super-gripes towards Autodesk in this ridiculous attempt to add automated hanger rods and supports. Quote
