silverado 10 Posted November 28, 2012 I'm trying to insert an panelboard from the tool palette of MEP 2012. I've managed to insert it, but when checking the properties, it's listed 1phase. How do I change it to 3 phase? Quote Share this post Link to post Share on other sites
ReMark 58 Posted November 28, 2012 FYI - There is a MEP forum listed under the heading AutoCAD Vertical Products. Have you done a search by any chance? Quote Share this post Link to post Share on other sites
silverado 10 Posted November 28, 2012 Thanks. I check that. Quote Share this post Link to post Share on other sites
tzframpton 32 Posted November 29, 2012 I'm trying to insert an panelboard from the tool palette of MEP 2012. I've managed to insert it, but when checking the properties, it's listed 1phase. How do I change it to 3 phase?This is a one-time operation that's done when you're adding the Panel into the drawing. Follow these steps: Click the Panel you want to insert into the drawing. DO NOT set the panel yet. Notice on the Properties Palette, there are orange asterisks beside a few items. These are some of the properties you can change before you set the panel in place. Even though there's no orange asterisk beside the Phase, you can change it from single to three phase. This is how you preset the Panel. Once it's set, I do not believe it can be changed, you'd have to re-insert a Panel. Here is a link to some further documentation: http://exchange.autodesk.com/autocadmep/enu/online-help/browse#WS46b90c3cb2c58cad1e9cb75fe2b27757e-7ff0.htm Hope this helps! Quote Share this post Link to post Share on other sites
