  • Replies 31
  • sean214
    17
  • ReMark
    5
  • JD Mather
    3
  • rkent
    3
Posted Images
If you draw it up in 3D you have the four standard isometric views to pick from as well as the option to rotate the model anyway you want.
JDM: Have you given up on providing any further assistance to sean?
Sean, is this something you are required to draw in 2D isometric? If so then the wire locks are going to be virtually impossible. Have you got a decent Acad instruction book that covers the basics such as osnaps and command line prompts? Never fear, it gets easier
Try to give specifics on where you are stuck and people will try to help you along.
PS...whilst the world is indeed not flat, I imagine that being patronised wasn't particularly helpful. This is the beginners forum (why I spend alot of time here!) have patience with posters!
Were you given instructions that specifically said to draw everything in isometric or just to provide an isometric view? There is a difference...subtle as it may be.
not everything but only the assembly...i did get it done, thanks
all the instructions are in my first post...however i did manage to get it done, thanks
post the results? would like to see how it turned out
Sean, glad to hear you got the job done. By the way, I was sticking up for you in what I said.
It looks pretty good, place your viewports on a no-plot layer so they won't show when printing.
Thanks. the final version looked much better when i printed it out on a plotter. I did also fix the viewports.
JD Mather, just wondering. i just noticed the pct.edu link with tutorials. do you teach at that school? if you do i do i use to go there.
