Hvac Duvting
How do illustrate a set down transformation piece from a top elavation in a drwaing
Welcome to the CADTutor forum keithozim.
Just to clarify your question, you want to draw a step-down transformation in plan view, correct? Are you going from a square or rectangle duct down to a circular duct? A little more detail would be appreciated. Thank you.
I am going from rectangular to rectangular duct.
I would draw it with the larger rectangle shown as a solid line and the smaller rectangle as a dashed line. Something like this:
Duct_transition.dwg
I don't normally draw ductwork so if I am wrong I ask that someone correct me. Thanks.
If the duct is "stepping down" as in changing elevations within the transition, then you note it - don't sorry about displaying it. Attached is an example with elevation notes to clarify. :)
I totally got that wrong.:oops: Thanks for educating both of us Styk. I thought he had one duct under the other. Ohhh...back to school I go.:(
haha, not a problem Mark. This is my trade, so naturally I will know the answer. I'm still not sure of his exact question, because its still a bit unclear, but I think I answered what he's after. We will see if he posts back. :)
Styk: The numbers in the boxes, are they the elevation notes? If so, how are they read?
Top of the box is the top height of the duct A.F.F. Bottom box is the bottom height of the duct A.F.F.
the duct size (ie: 36x24) is always 36" wide by 24" tall. :)
Thanks for the lesson Styk. Now I know why you're called DUCTMAN.
  • 2 months later...
lll888: Are you sure you're in the right thread?
This exact post was in the LISP forum not too long ago - a spammer me thinks...
I don't know really, I really should be in bed - got a 9am lecture tomorrow morning as well... just thought I'd browse the forums for a bit :)
Just been listening to Sting singing "I'll be wrapped around your finger...." (thought I'd look up your sig...) :P
Well good night. Get some shut eye or you'll be dozing in class instead. See ya.
Really...stop listening to Sting and go...to...bed.
you'll be dozing in class instead...
Haha, no change there then :P
Night Mark
